gfleming
Jul 19, 2016Follower
Best Netgear range extender to use with Netgear R6250 Router
 I purchased a Netgear AC-1600 R6250 Smart WiFi router.  It works great but I would like to extend the range and coverage in my home. Currently, the router is located in our basement, as it is hard wi...
- Jul 21, 2016Hello gfleming It is really up to you and your budget the higher models have a better coverage for larger houses but any of them should work for what you are trying to do. DarrenM
DarrenM
Jul 21, 2016Sr. NETGEAR Moderator
Hello gfleming
DarrenM
