Karaptian
Apr 05, 2017Aspirant
Best Netgear range extender to use with Netgear R6250 Router
 I'm running the R6250.     I would like to know which Range Extenders will work with this router?
DarrenM
Apr 07, 2017Sr. NETGEAR Moderator
Hello karaptian
I would suggest any of the AC extenders.
DarrenM
NETthisGEAR
Apr 07, 2017Apprentice
Depending on your price range - you can go for the EX3700 which isn't as expensive as the EX6150(which offers more/improved features). If you want a top end extender then the you can look at the EX7300.
