luckycat889
Mar 29, 2020Initiate
Best products for extending wifi between buildings
Hello Community, Right now I've got a Netgear cable model/wifi router (DOCSIS 3.0/ac). I would like to extend/bridge this wifi network to another building, perhaps 125 ft away. There is a clear view...
- Mar 29, 2020
You could try an extender but for that disance, I'd recommend a point to point system. You can find them on amazon or Netgear makes a version called airbridge
Mar 29, 2020Guru - Experienced User
luckycat889
Apr 01, 2020Initiate
Right, I think I will try out Airbridge, it's claiming 500 mbit/s at 166 m distance, which should suffice. Thanks for the piece of advice!
