Vapor
Jun 04, 2012Novice
Best range for 6 wireless access points??
I have a house that has 16 rooms, approx 20,000 square feet, 2 floors, it has ethernet in wired into 6 of the rooms. There is a main rack in the centre of the house on the ground floor with the broadb...
Vapor
Jun 04, 2012Novice
I want to use the wired connections into all the rooms with wireless access points attached.
When connecting the access points up, what channels shall i use for the 2.4Ghz and 5Ghz? Can i use 1 ssid, so that when walking around the house there will be a seamless connection on mobile devices.
Does anyone know when a wireless printer attached to the single ssid, can anyone on that wireless network print to the wireless printer?
