Vapor
Jun 04, 2012Novice
Best range for 6 wireless access points??
I have a house that has 16 rooms, approx 20,000 square feet, 2 floors, it has ethernet in wired into 6 of the rooms. There is a main rack in the centre of the house on the ground floor with the broadb...
jmizoguchi
Jun 04, 2012Virtuoso
Does anyone know when a wireless printer attached to the single ssid, can anyone on that wireless network print to the wireless printer?
why not?
I want to use the wired connections into all the rooms with wireless access points attached.
openmesh products or any AP will work with wired
When connecting the access points up, what channels shall i use for the 2.4Ghz and 5Ghz? Can i use 1 ssid, so that when walking around the house there will be a seamless connection on mobile devices.
All different from overlapping.
both band should have different SSID>
seamless = roaming ..... depending on how the mobile device will adapt to each AP
ex. google roaming aggressiveness , you will see how computer has setting that helps to roam better...
