Vapor
Jun 04, 2012Novice
Best range for 6 wireless access points??
I have a house that has 16 rooms, approx 20,000 square feet, 2 floors, it has ethernet in wired into 6 of the rooms. There is a main rack in the centre of the house on the ground floor with the broadb...
Vapor
Jun 04, 2012Novice
When having one ssid, do i just use 1 password for all access points?
The connection im running at the moment is:
Adsl router to gigabit unmanaged switch, ethernet from switch to access points.
So do i give each access point its own ip address outside the Dhcp but on the same subnet?
DHCP range= 192.168.1.10 to 192.168.1.100
Router= 192.168.1.1
AP1= 192.168.1.2
AP2= 192.168.1.3
AP3= 192.168.1.4
And so on for the 6 access points?
Router= 192.168.1.1
AP1= 192.168.1.2
AP2= 192.168.1.3
AP3= 192.168.1.4
