Sharam55
Dec 31, 2020Aspirant
Best way to configure home WiFi with 3 Range Extenders + Xirrus XR-620
What's the best way to configure my Netgear Router and 3 Netgear Range Extenders to share the same SSID and achieve smooth transition from room to room. Can the Xirrus XR-620 share the same SSID...
Sharam55
I forgot to mention that I would like to configure the range extenders using hard wire. My home is wired and I think I will get the fastest setup if I avoid the range extenders communicating with each other through WiFi.
Dec 31, 2020Guru - Experienced User
ouch.
The mesh extenders only function as mesh when ran in extender mode. In access point mode (hardwired), they don't function as mesh because they're their own AP and not part of the mesh. They won't be seamless in that mode.
And daisy chaining multiple extenders tends to results in instability.
Same with using a bunch of extenders.
I tend to tell anyone needing more than 1 extender, to move to an actual mesh system like netgear orbi. And go triband. I'm not a fan of the dual band setups.
But you can try to make it work.
If you want seamless, you'd want the extender option. The EX7700 and EX8000 will be fairly tolerant of it because of their dedicated backhaul. The EX7000 will have a 50% speed hit because its a dual band.
Try to star configure them not daisy chain.
Star: Extender<----------router----------->extender
V
Extender
- Sharam55Jan 13, 2021Aspirant
I setup the EX8000 as an Access Point and connected it to the router as hardwired.
Transitions between access points is not as smooth but I am getting much better speed.
I am still a bit confused if this setup is optimal.
Thanks for you help.
