Sharam55
Dec 31, 2020Aspirant
Best way to configure home WiFi with 3 Range Extenders + Xirrus XR-620
What's the best way to configure my Netgear Router and 3 Netgear Range Extenders to share the same SSID and achieve smooth transition from room to room. Can the Xirrus XR-620 share the same SSID...
Johnson456
Jan 13, 2021Aspirant
Find the default IP Address for your xirrus router, modem, and other devices. then configure.
Sharam55
I am able to access all the devices and configure each device. I would like to know what parameters to use for optimal coverage and speed.
- plemansJan 13, 2021Guru - Experienced User
Optimal coverage takes testing.
there isn't a specific setting to change.
but you can try different locations to see what works for you best. I usually move my access points/extenders around a few times to check optimal placement
- Sharam55Jan 15, 2021Aspirant
Thank you for your advice.
