Hello1981
May 04, 2020Aspirant
Best way to wire 2 range extenders?
Okay my question is simple, what is the best way to hard wire 2 range extenders, I have a central rx200 router, that distributes my wifi to my entertainment room and my kitchen. Now I want to add ran...
May 05, 2020Guru - Experienced User
A questions
1. What range extenders do you have or plan on buying?
Best route?
Extender<-----wired------->router<--------wireless------->extender
a hardwired connection is always going to be faster/more reliable than wireless. so I'd run the 1 extender wired then run the other extender directly off the router. You can always wire it in or try it wireless and see how well it functions.
I would never recommend running extenders daisy chained. Reason why?
To keep in simple, every extender in the chain cuts throughput 50% and increases latency. Tri-band extenders mitigate that but they'll still have latency increase and a smaller speed decrease.
