sam022
Oct 14, 2016Aspirant
Best WiFi extender for gaming online? (XboxOne)
Hello, Does anyone know what the best WiFi extender is for online gaming?
DarrenM
Oct 19, 2016Sr. NETGEAR Moderator
Hello sam022
I would look at the Ex3200 which is the low end of the AC extenders up to the EX7300 it just depends on your budget but you will want a dual band AC extender since your router is dual band AC.
DarrenM
NETthisGEAR
Apr 07, 2017Apprentice
Honestly, I'd get a better router if at all possible. Otherwise if you need an extender then get the EX7300.
The R9000 can probably reach where you need it to, although it's hard to say for sure.
If that can't then the Orbi certainly can. For gaming I'd go with the Orbi and a satellite over a router and the extender. Extender cuts into your bandwidth, but it has it's place and can ork great for gaming of course.
