dbandy
Apr 30, 2020Follower
Best Wifi Range Extender for Nighthawk AX6 6-stream WiFi Router AX 4300 Model#RAX45
Any recommendations for the Best Wifi Range Extender for use with Nighthawk AX6 6-stream WiFi Router AX 4300 Model#RAX45? Just installed the Router today and it is lightning fast, but the signal does...
- May 07, 2020Try also the cheaper version instead of EAX80. Purchase EAX20. It’s their newest addition to the extenders. I have RAX45 router and EAX20 extender. It works beautifully. Note the EAX20 is 4 stream unlike EAX80 which is 8 stream. But EAX20 runs $149.00 EAX80 costs $249.00
May 01, 2020Guru - Experienced User
The best? Probably the EAX80
Depending on what you're doing, I've got the EX8000 and it more than covers what I need.
- sleekoneMay 03, 2020Tutor
I too use the EX8000 with my new Nighthawk RAX45 and it does a nice job extending both 2.4 and 5ghz to a area of the house that was having reception issues. I configured it to use it's own SSID so I'm clear which radio I'm connected to.
