JassonRM's avatar
JassonRM
Best wired access point for seamless roaming paired with R7000
Hi, I´m looking to buy an access point for a bedroom with wired ethernet connection, ideally it would provide seamless roaming with the main router and have wired ethernet ports. Does any router or e...
  • StephenB's avatar
    Sep 14, 2018
    The EX7000 should do that (letting you set the network name and passphrase to match your router).
    Ultimately it's up to your client devices to actually switch to the extender network, there's nothing the extender can do to force the switch.  However, generally clients will switch when they see a much stronger signal.
