terryger's avatar
terryger
Novice
Feb 09, 2012
blocked site
i have a wnr2000v2 works good but i have a problem with keeping a site blocked i've had to use keywords like internet bypass,hidemyass,proxies,proxify.com,proxy an these worked for a while till lately cus now their getting to the site and it don't show up on my logs so i can't see what other keywords i should use this is in regards to that dating site pof an this is the only site i want blocked can anyone help me with this?
  • Retired_Member's avatar
    Retired_Member
    If your router has a log option use it see what sites you access and then copy the sites to your block list.
    Retired_Member
    I miss read your OP never mind my response .
  • the url they were using proxys to get around my firewall so i have it in my keywords also an using the sites name in keywords thing is their getting there an it don't show up in my log file
  • You have to block ports
    Keyword is ONLY for URL
    Google wireshark and find the ports are used
  • installed the program an using it, now just waiting for them to access that site.nice program,should show me what i'm looking for. thanks for turning me on to it.
    terry
  • look for at the ports are used ... you have to capture the log and look at it
