DaveinHenderson
Aug 12, 2022Aspirant
Booster vs. Extender in existing network
I want to increase the strength of my existing Wi-Fi signal in part of my house (network is Net Gear Nighthawk), but not create separate networks. I bought an EX6120 Extender and on page 5 of the st...
Molarka
Aug 13, 2022Aspirant
DaveinHenderson wrote:I want to increase the strength of my existing Wi-Fi signal in part of my house (network is Net Gear Nighthawk), but not create separate networks. I bought an EX6120 Extender and on page 5 of the start-up guide it shows that 2 separate networks are being set up. Looking up the definition on a router blog says: "booster acquires existing signal and rebroadcasts to create a second network". and "an extender intercepts the signal, magnifies it, and transmits it". So what product does what I want? Does Net Gear offer one? Obviously the EX6120 is not what I want. Thanks. DaveinHenderson
A Wi-Fi extender amplifies the existing signal but does not strengthen the signal. On the other hand, a Wi-Fi booster converts your existing coax wiring into a fast, stable network connection and signal strength.
Follow these steps for trying to extend wifi signal but not guranteed that it will work:
- Select a Good Place for Your Router. Not all places are equally suitable for your router.
- Keep Your Router Updated.
- Get a Stronger Antenna.
- Cut Off WiFi Leeches.
- Buy a WiFi Repeater/ Booster/ Extender.
- Switch to a Different WiFi Channel.
- Control Bandwidth-Hungry Applications and Clients.
- Use the Latest WiFi Technologies.
