LifeIncome
Dec 08, 2022Guide
Bought two AX8 Extender's. ? on how to set-up the 2nd AX8
When I add the 2nd extender via the app the 1st extender disconnects from my netgear home router network. How do I connect the 2nd w/out disconnecting the 1st?
LifeIncome
Dec 08, 2022Guide
Ok, did that. But when i go to the app and look at devices it says no devices connected. So how do I know that they are both working?
Dec 09, 2022Guru - Experienced User
The app for what device? the router? the extender?
Did you set the extenders up in mesh mode? If so, its the devices (phone/tablet/etc) that chooses when to roam between the router and the extender. Or you can disable the mesh function and program them yourself.
- LifeIncomeDec 09, 2022Guide
Nighthawk app. Netgear AC3200 Router. EAX80 Extender. And I did Not know one could disable the mesh fnc.
They currently seem to b both working.
- michaelkenwardDec 09, 2022Guru - Experienced User
AC3200 Router.
Which ones?
iOS or Android app? (They seem to be going through a "pass the bug" phase at the moment.)
Which AC3200 router? R6300v? R7850? R8000?
All claim to have that wifi technology.
3200. Android.
