Smitht308
May 01, 2018Follower
Bought used how do i unlock it
Okay, Im using an old linksys 2.4 router its what have though. We bought this universal wifi range extender thinking it was a better router. well i tried to hook it up and i cannot use it because i ...
DarrenM
May 02, 2018Sr. NETGEAR Moderator
You will need to hold the reset button for 10+ seconds then the default login will be admin/password
DarrenM
