trailerpark37's avatar
Dec 03, 2020
browser login wifi networks and the extender
we are at a trailer park, and we have a device that needs to connect to an ethernet wire, but the park only has wifi.  The wifi is such that there is no WPA security, instead it's a password typed into the park webpage after login.
I had an extender I didn't need anywhere else, and it has an ethernet port on it, so i thought I could connect it the park wifi and plug in the wired device.   However, it won't stay connected (extender keeps dropping the wifi since it cannot log into the browser security).
Thoughts?
1 Reply
  • plemans's avatar
    You need a device that supports wisp mode.
    LIke a travel router. Netgear made one but its quite old. There's much better options out there.
    Just search amazon/google for travel router. Most support wisp mode.
