CB50
Dec 02, 2013Aspirant
BT Home Hub with Netgear Devices
I have tried quite a few times to correct this but cannot.
Current System: BT Home Hub 3 used as modem and DCHP (not used for wireless). Connected to an unmanned NetGear Switch with network cabling running around the house. WNDR 3700 routers around house used for wireless and switches.
Within the Netgear Routers i cannot turn on scheduling or update the time or live parental controls.
I am basically trying to setup the system so that i can disable access for the kids devices at certain times and control age related content - with iphones/pads and kindles it is difficult to control on the devices.
Any tips or advice is very welcomed.
Thanks
Colin
Thanks
Colin
- jmizoguchiVirtuosolook in to subscription base service such as http://www.mobicip.com
- CB50AspirantThanks - will look at that.
Anyone help with the router issues?
Thanks
Colin - jmizoguchiVirtuososwitch only passes traffic for unmanaged switch so you should control any but pass the traffic
