jjsh
May 25, 2020Aspirant
buffering issues on nighthawk ac1900
nighthawk1900 set up on 1st floor of house. Basement TV seems to buffer alot. Is it my nighthawk or my cable connection.
jjsh
May 26, 2020Aspirant
1-model is R7000, not sure how to check for firmware
2-1080p
3-Roku
4-2.4ghz, but wifi is capable of both
5-3700 sq ft
6-sheetrock walls with wood studs. Hvac has aluminum tubes and tape
Hope this helps
Thanks
jjsh
May 27, 2020Guru - Experienced User
jjsh wrote:1-model is R7000, not sure how to check for firmware----Key detail with the r7000 as its not known for the best firmware. you can look on the router status page.
2-1080p
3-Roku----which one?
4-2.4ghz, but wifi is capable of both----should always be on the 5ghz for streaming if possible. it has much higher throughput for streaming.
5-3700 sq ft----thats a big house for a single router setup. I have a 3200 sqft home and run an orbi plus 2x satellites in mine.
6-sheetrock walls with wood studs. Hvac has aluminum tubes and tape-----moving devices around might help if there's hvac in the walls blocking signals possibly.
Hope this helps
Thanks
jjsh
