CyofClive
Sep 04, 2020Follower
C Link light is blinking yellow
I have the Model MCA 1001 v2 that I have been using for several years. About a week ago the C Link light started blinking yellow. What does this mean? All cables are connected.
1 Reply
here's from the manual:
C LINK
• Solid green. The phyrate is 180 Mbps.
• Solid yellow. The phyrate is 150—180 Mbps.
• Flashing yellow. The coax cable is not connected.
• Off. The phyrate is less than 150 Mbps, or there is no power.maybe somewhere in the line there's damage, kinks, corrosion. Have you tested the 2 moca devices between a standard coax cable to make sure they work?
