Silipaq
Dec 13, 2019Follower
C3700 cable connection in progress?
Hello, I need some help by what the subject says, my cable connection on the (netgear genie) says it's in progress...can anyone help me understand by what that means, I've tried resetting my router an...
Dec 13, 2019Guru - Experienced User
Click on that icon.
It'll show up your cable connections page. That'll show us your connections/strengths and potential issues.
if you have any splitters/attenuators/amplifiers in the line, remove them. also make sure your cable connections are tight and that you aren't using cheap/corroded ends on them. You can also check for kinked/worn coax cables. These can all create connection issues.
