sesty7
Jan 21, 2022Guide
C6900 Bridge Mode w Velop Mesh
I have a c6900 which replaced the gateway provided by Xfinity. Looking at options for mesh wifi and saw a sale on the Velop system. As part of the set up, I would have to put the C6900 into brid...
sesty7
Jan 24, 2022Guide
thanks for the repsonse!
Seeing as I would need to have a second wifi w separate SSID I am assuming it would be cheaper just to buy a singular WAP and just run the secondary wifi from that? That would give me similar features to having a Velop or Orbi system in AP only mode?
Jan 24, 2022Guru - Experienced User
The C6900 isn't a mesh system. You could use a mesh extender if you'd like.
Or you could use an access point. An access point wouldn't roam with the same efficiency as a full mesh system but most devices have their own roaming protocol built in and roam pretty decent.
- sesty7Jan 24, 2022Guide
Got you. So the Velop even in WAP mode is still mesh between the 2-3 nodes - just a separate network
My existing xfinity rounter/modem would still be active and service the hardwired accessories plus the main Velop Node?
They would be within like 2-3ft of each other, would that cause interferance?
thanks
- plemansJan 24, 2022Guru - Experienced User
sesty7 wrote:
Got you. So the Velop even in WAP mode is still mesh between the 2-3 nodes - just a separate network ---correct.
My existing xfinity rounter/modem would still be active and service the hardwired accessories plus the main Velop Node?---if you left the C6900 in router mode, yes.
They would be within like 2-3ft of each other, would that cause interferance?---only if you put the wireless channels on the same ones. Seperate them out and they should be fine. I use it all the time.
thanks
