sesty7
Jan 21, 2022Guide
C6900 Bridge Mode w Velop Mesh
I have a c6900 which replaced the gateway provided by Xfinity. Looking at options for mesh wifi and saw a sale on the Velop system. As part of the set up, I would have to put the C6900 into brid...
Jan 24, 2022Guru - Experienced User
The C6900 isn't a mesh system. You could use a mesh extender if you'd like.
Or you could use an access point. An access point wouldn't roam with the same efficiency as a full mesh system but most devices have their own roaming protocol built in and roam pretty decent.
sesty7
Jan 24, 2022Guide
Got you. So the Velop even in WAP mode is still mesh between the 2-3 nodes - just a separate network
My existing xfinity rounter/modem would still be active and service the hardwired accessories plus the main Velop Node?
They would be within like 2-3ft of each other, would that cause interferance?
thanks
- plemansJan 25, 2022Guru - Experienced User
sesty7 wrote:
Got you. So the Velop even in WAP mode is still mesh between the 2-3 nodes - just a separate network ---correct.
My existing xfinity rounter/modem would still be active and service the hardwired accessories plus the main Velop Node?---if you left the C6900 in router mode, yes.
They would be within like 2-3ft of each other, would that cause interferance?---only if you put the wireless channels on the same ones. Seperate them out and they should be fine. I use it all the time.
thanks
