sesty7
Jan 21, 2022Guide
C6900 Bridge Mode w Velop Mesh
I have a c6900 which replaced the gateway provided by Xfinity. Looking at options for mesh wifi and saw a sale on the Velop system. As part of the set up, I would have to put the C6900 into brid...
sesty7
Jan 25, 2022Guide
Please excuse my ignorance
Xfinity Gateway> ethernet to exiting accesories
Xfinity Gateway > ethernet to Velop (in bridge)
Xfinity Gateway> ethernet to child node (also in bridge mode?) on opposit side of house
all would use the existing network and same SSID?
wont there be potential for interferance with the existing Gateway and Parent node so close to each other?
The image attached is my current set up, just looking for a way to get a higher quality interent connection to the WFH set up upstairs. I have no options to relocate the gateway.
Jan 25, 2022Guru - Experienced User
Xfinity Gateway> ethernet to exiting accesories----by xfinity gateway you mean the C6900?
Xfinity Gateway> ethernet to child node (also in bridge mode?) on opposit side of house----not sure what this "child" node you're referring to is.
all would use the existing network and same SSID?---the velops would be on their own ssid wireless. But wired, they'd all be on the same subnet.
wont there be potential for interferance with the existing Gateway and Parent node so close to each other?---Not if you seperate out the wireless channels.
