leroy03
Nov 03, 2020Aspirant
Can’t connect devices to extender
I have set up my extender and am ready to use it. However, when I try to connect my devices, it tells me my WiFi password is incorrect. I am using the same password as I always do for my regular WiFi modem. Any ideas of what to do?
What router did you set it up on?
what firmware is on the extender?
did you set it up using wps? if so, try factory resetting and reinstalling using the installation assistant.
