leroy03
Nov 03, 2020Aspirant
Can’t connect devices to extender
I have set up my extender and am ready to use it. However, when I try to connect my devices, it tells me my WiFi password is incorrect. I am using the same password as I always do for my regular WiFi ...
Nov 03, 2020Guru - Experienced User
which centurylink router?
Have you tried reinstalling it using the installation wizard? (Not wps)
leroy03
It is a 802.1 1n router through century link. I have not tried the other method yet.
- plemansNov 03, 2020Guru - Experienced User
centurylink has many routers. An actual model helps.
But try the installation assistant first
- leroy03Nov 03, 2020AspirantI can’t use the installation assistant because my laptop won’t connect the the extender.
Where is it failing in the process?
What error is it giving you?
Did you try factory resetting the extender? push and hold reset for 7-15 seconds while its fully powered on?
