leroy03
Nov 03, 2020Aspirant
Can’t connect devices to extender
I have set up my extender and am ready to use it. However, when I try to connect my devices, it tells me my WiFi password is incorrect. I am using the same password as I always do for my regular WiFi ...
leroy03
I can’t use the installation assistant because my laptop won’t connect the the extender.
Nov 03, 2020Guru - Experienced User
Where is it failing in the process?
What error is it giving you?
Did you try factory resetting the extender? push and hold reset for 7-15 seconds while its fully powered on?
