Sandpipa
Apr 17, 2020Tutor
Can’t connect N300 wireless range extender
Hi, I'm trying to connect my N300 range extender for the first time. I've tried the WPS method, but the router light doesn't come on. Therefore I've tried the second method, but can't see a N...
- Apr 17, 2020
yes, try the installation wizard.
Sandpipa
Apr 17, 2020Tutor
Just to add, I'm trying to connect to a TalkTalk router. Thank you!
Apr 17, 2020Guru - Experienced User
maybe the netgear was setup prior. Try a factory reset. While the extender is fully powered on, push and hold reset for 7-15 seconds. The lights should flash wen you've held it long enough.
Then try the install.
You can also hardwired into many of netgears extenders (not all) and set it up that route.
Btw, if you still have issues, some of talktalk routers don't play friendly with extenders as they make their own. Which one do you have specifically?
- SandpipaApr 17, 2020Tutor
Hi, thanks very much for replying, much appreciated.
i've just tried the factory reset but it's still not recognising the router, unfortunately. The model is DSL-3782.
How would I do it via hardwire? Just plug an ethernet cable into both devices and follow the same procedure?
Many thanks again!
- plemansApr 17, 2020Guru - Experienced User
plug your desktop/laptop into the extender. Make sure the wireless is off on whatever device you connect to the extender. Or it'll default back to the valid wireless connection.
then try going through setup that route.
Thank you, do you mean by trying to connect with the Netgear installation assistant instead of WPS?
