Sandpipa
Apr 17, 2020Tutor
Can’t connect N300 wireless range extender
Hi, I'm trying to connect my N300 range extender for the first time. I've tried the WPS method, but the router light doesn't come on. Therefore I've tried the second method, but can't see a N...
- Apr 17, 2020
yes, try the installation wizard.
Apr 17, 2020Guru - Experienced User
plug your desktop/laptop into the extender. Make sure the wireless is off on whatever device you connect to the extender. Or it'll default back to the valid wireless connection.
then try going through setup that route.
Sandpipa
Apr 17, 2020Tutor
Thank you, do you mean by trying to connect with the Netgear installation assistant instead of WPS?
