Sandpipa
Apr 17, 2020Tutor
Can’t connect N300 wireless range extender
Hi, I'm trying to connect my N300 range extender for the first time. I've tried the WPS method, but the router light doesn't come on. Therefore I've tried the second method, but can't see a N...
- Apr 17, 2020
yes, try the installation wizard.
Sandpipa
Apr 17, 2020Tutor
Thank you, do you mean by trying to connect with the Netgear installation assistant instead of WPS?
