FrogandTea33
Apr 17, 2023Follower
Can’t connect to mywifiext
I have just got a new wifi modem and I cannot connect to the mywifiext page at all, as well as while I am connected to the extenders internet “NETGEAR_EXT” it says I have no internet as well. I have t...
Apr 17, 2023Guru - Experienced User
What actual device do you have? The ac number is a speed, not a model.
What router are you connecting it to?
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
