Spoonfingers's avatar
Spoonfingers
Can’t login to WiFi Range Extender
I want to login to the range extender to change its name on the network, but I can’t access the login interface via mywifiext address <br><br>It just says page not found? I’ve tried Safari and Firefox on my MacBook Pro and also my iPhone. I’m definitely using the extender on my WiFi whilst attempting the login, I’ve even connected to the main WiFi just for kicks. I’ve also tried the standard IP suggestion but still the same results?!<br><br>Does this range extender not allow for this? Am I missing something obvious? Is there any other way? Or is my Vodaphone router blocking this attempt?<br><br>Please can someone put me out of my misery. 👍🏼
  • Just to clarify the extender just shows up as standard router name + _ext but I want to name it separately to the main router with a name of my choice.
  • plemans's avatar
    have you tried logging into it using the IP address the vodaphone gives to it?
    Have you tried a different browser?
    Or even tried hardwiring into it for setup/changes?
    • Spoonfingers's avatar
      Spoonfingers
      Yeah, as above, I’ve tried the IP and two different browsers. As for hard wiring it, the MacBook Pro is wireless only, no Ethernet port.
      • plemans's avatar
        what IP address?
        What are the led's on the extender doing?
        did you try setup via wps and/or using the installation wizard?
