Spoonfingers
Sep 13, 2020Aspirant
Can’t login to WiFi Range Extender
I want to login to the range extender to change its name on the network, but I can’t access the login interface via mywifiext address <br><br>It just says page not found? I’ve tried Safari and Firefox...
Spoonfingers
I’ve used the IP address of the WiFi extender
Connected using WPS without issue and runs quick and boosted the signal range well, so happy with that. Lights are green as expected.
Spoonfingers
I can access the main vodaphone router no problem via IP but I don’t want to touch that, but for some reason I can’t access the Netgear range extender via its IP. It’s a strange one. All the troubleshooting says is that I mustn’t be connected to the ext WiFi Whilst trying to connect to the login page, but I definitely am. ??!
- plemansSep 13, 2020Guru - Experienced User
What ip address is the vodaphone giving you for it?
what one are you using?
Can you ping that address?
