Spoonfingers
Sep 13, 2020Aspirant
Can’t login to WiFi Range Extender
I want to login to the range extender to change its name on the network, but I can’t access the login interface via mywifiext address <br><br>It just says page not found? I’ve tried Safari and Firefox...
Spoonfingers
I can access the main vodaphone router no problem via IP but I don’t want to touch that, but for some reason I can’t access the Netgear range extender via its IP. It’s a strange one. All the troubleshooting says is that I mustn’t be connected to the ext WiFi Whilst trying to connect to the login page, but I definitely am. ??!
Sep 13, 2020Guru - Experienced User
What ip address is the vodaphone giving you for it?
what one are you using?
Can you ping that address?
