cavedon
Jan 19, 2018Aspirant
Can EX3700 act as DHCP and NAT?
Hi, I am planning to use an EX3700 AC750 WiFi Range Extender for an untrusted wifi network. Can the EX3700 act as NAT and DHCP? Even when the network being extended is not available? Thanks, Lu...
DarrenM
Jan 24, 2018Sr. NETGEAR Moderator
No it can not.
DarrenM
- cavedonJan 24, 2018Aspirant
Thank you Darren,
What would you recommend instead? EX6100?
Thanks,
Ludovico
- DarrenMJan 25, 2018Sr. NETGEAR Moderator
none of the extenders will handle DHCP you will have to use a router for that.
DarrenM
- cavedonJan 26, 2018Aspirant
I see from https://kb.netgear.com/24431/How-to-enable-NAT-of-EX6100 you can enable NAT on an EX6100.
What device will assign IP addresses to the clients behind NAT? Will the EX6100 assign addresses?
Or are you saying that NAT on a EX6100 will not work without an additional router?
Do you have a router that can also act as ane extender?
