MKC9582's avatar
MKC9582
Initiate
Mar 02, 2021
Can I Configure EX6150 to Use WPA2 only
Am looking to purchase a home WiFi extender but want to configure to use WPA2 only and disable WEP and WPA. I cannot find documentation that shows how this configuration can be done. Is it possible and if so how can it be done.
Many thanks for assistance
MKC9582
  • Thanks for the information. I guess I was trying to make it difficult! I'll go ahead with my purchase.
    Thanks
    MKC9582
  • plemans's avatar
    You don't need to disabled wep/wpa, you just need to select wpa2 as your security setting.
    • MKC9582's avatar
      MKC9582
      Initiate
      Thanks
      MKC9582
