sirishoggu's avatar
sirishoggu
Follower
Mar 02, 2017
Can I configure WNDR3400 N600 Wireless Dual Band Router to NetGear WN3000RP-200INS
Hello All,
I have bought NetGear WNDR3400 N600 Wireless Dual Band Router from Amazon an year back and its working fine.  Now I am looking for an WiFi Range Extender as the present router is in first floor of my building and is not giving good range in the ground floor. So, I would like to know if NetGear WN3000RP-200INS Universal WiFi Range Extender does support the router which I m using.
Please advice.
Sirish Oggu
  • Hello sirishoggu
    Yes this should work just fine.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello sirishoggu
    DarrenM
