David058
Feb 27, 2021Aspirant
Can I connect 2 routers to Nighthawk AC2200
Hello I have purchased and connected the Nighthawk AC 2200 extender to my xfinity advanced gateway router. I also have a Linksys EA 6100 connected to my Xfinity router. Can I connect the Linksys also...
Feb 28, 2021Guru - Experienced User
I'm confused as to what you're doing.
You're wanting to connect your linksys router to your netgear extender simply for additional ethernet ports?
Is this correct?
A cheap gigabit switch would work as well and wouldn't cause double nat issues or wireless interference issues.
