pabloeskumar
Aug 21, 2023Aspirant
Can i connect a Belkin F9K1015 (Wifi Extender) to a Orbi RBR50 router?
Greetings, I would like to know if i can connect a Belkin Wifi Extender (F9K1015) to the orbi RBR50 router? Also, i want to know if i plan to get a orbi 960 series, what kind of wifi extenders ...
Aug 21, 2023Guru - Experienced User
For that size of home, a RBR and just one satellite would be enough, maybe too with the power reduced on the router for the MESH system. Too Much Wifi: https://youtu.be/UR0viMLISz4
pabloeskumar
thanks for the video dude. but what do you think about adding a TP-Link RE705x in that setup even if i wanted to? technically it will work right?
Do wifi extenders need to connect to the router directly or it can also work with a satellite at the end of the network. ?
