pabloeskumar
Aug 21, 2023Aspirant
Can i connect a Belkin F9K1015 (Wifi Extender) to a Orbi RBR50 router?
Greetings, I would like to know if i can connect a Belkin Wifi Extender (F9K1015) to the orbi RBR50 router? Also, i want to know if i plan to get a orbi 960 series, what kind of wifi extenders ...
Aug 21, 2023Guru - Experienced User
I can't personally recommend something in particular. From prior experience I can't recommend any thing TP-Link.
NG has EX and EAX series extenders for support of additional wifi extending if needed that would work with the RBR50.
Might find a used RBS50 on amazon or maybe shopgoodwill.com if you want to keep good integration with the RBR.
pabloeskumar
oh, i am asking about the TP-LINK re705x or any of the NG extenders that can work with Orbi 960 series. what are your thoughts on it?
- FURRYe38Aug 21, 2023Guru - Experienced User
That extender doesn't support 6ghz which the 960 does.
"574 Mbps at 2.4GHz, 2402 Mbps at 5GHz" these rates are below what the 960 supports.
- pabloeskumarAug 21, 2023Aspirant
so what extenders do you think is better that would work with the 960?
If I had to have something, the EAX80.
However for that size of home, the RBR and one RBS would be enough and you'll not need any extenders.
