pabloeskumar
Aug 21, 2023Aspirant
Can i connect a Belkin F9K1015 (Wifi Extender) to a Orbi RBR50 router?
Greetings, I would like to know if i can connect a Belkin Wifi Extender (F9K1015) to the orbi RBR50 router? Also, i want to know if i plan to get a orbi 960 series, what kind of wifi extenders ...
Aug 21, 2023Guru - Experienced User
That extender doesn't support 6ghz which the 960 does.
"574 Mbps at 2.4GHz, 2402 Mbps at 5GHz" these rates are below what the 960 supports.
pabloeskumar
so what extenders do you think is better that would work with the 960?
- FURRYe38Aug 21, 2023Guru - Experienced User
If I had to have something, the EAX80.
However for that size of home, the RBR and one RBS would be enough and you'll not need any extenders.
