Curlie028's avatar
Nov 28, 2021
Can I connect Powerline Ethernet into my Nighthawk?
Not sure if I am able to explain my query as I am very tech limited but here goes. I have a Netgear WiFi Booster Range Extender AC3000 (EX8000). I have bought a Powerline WiFi Adaptor Extender/Boost...
  • plemans's avatar
    Nov 28, 2021
    yes you can connect an extender to the router using powerline. You'd just need to re-run setup on the extender and set it up in access point mode.
