bekinde2all
May 19, 2023Aspirant
Can I extend wifi mesh by conneting a wifi mesh to another one?
I currently have a AC1900 WiFi Mesh Extender Essentials Edition Model EX6400v3 that is extending my wifi to my basement. The home router is on the top floor, the mesh extender is on the main level, c...
michaelkenward
May 20, 2023Guru - Experienced User
bekinde2all wrote:
.... can I add another one to the basement so I can hard wire something to the mesh extender in the basement?
Do you really need a mesh extender to get something hard wired on to the network?
As plemans points out the speed won't be great thanks to the wifi connection.
If it only a wired connection that you need, you could consider Powerline Ethernet.
to use the mains circuit to connect the wired device to the router.
