DDuffy's avatar
DDuffy
Follower
Jul 30, 2016
Can I upgrade WN2000RPT v1 with firmware for v2 or v3?
Can I upgrade WN2000RPT v1 with firmware for v2 or v3? If so, is there any good reason to do so? I want to use it with an ASUS RT-AC3200 triband router. Thanks for the help, DDuffy
  • DarrenM's avatar
    Aug 02, 2016
    Hello DDuffy
    No you can not upgrade the V1 with firmware from the V2 or V3
    DarrenM
