Terrixy
Jun 28, 2020Aspirant
Can I use a NETGEAR mesh range extender with other brand router and still have the mesh function?
Hi,
My currrent home wifi setup: an ac2600 dual-band router + powerline extenders (all from other vendors).
Problem: no mesh function, so often need to disable/enable the device wifi to connect to the nearest AP when moving around the house. And the powerline extenders do not seem to work reliably (drop out often).
I'm tempted to replace the current setup with an XRM570 set. But since the router works flawlessly, I wonder if I can simply get an EX7700 or EX8000 to complement it. I understand the extender should work with the router as a normal extender. But how about the mesh function? Or do I have to use a compatible NETGEAR router for that?
Many thanks!
Terrixy
You can use a different router and have the mesh function work.
A couple things to keep in mind through.
1. The mesh extenders work great when you're only using 1. if you're needing more than 1, a move to a full mesh system would be better.
2. The isn't a controller for the system like a true mesh system. It relies on your router and device's own roaming function to work in mesh.
so it should work with your system. its just a couple little points with how mesh extenders work
- TerrixyAspirant
Many thanks plemans. That's very helpful. Yes, I think 1 mesh extender is enough in my case.
