TimSTL
Jun 03, 2024Guide
Can I use an EX3700 to bridge between an Android cellphone working as a Hotspot and a wired LAN
Does anyone know if this is possible? I want to bridge between my Android cellphone, which is providing my only Internet connection, and my wired domestic intranet. I don't want a wired tether (i.e. ...
Jun 05, 2024Guru - Experienced User
another option to check into would be a router that supports WISP mode. That might work a bit better and reduce needing the intermediary.
TimSTL
Jun 06, 2024Guide
Thanks, Plemens, that's a good thought. WISP mode should allow me to connect as a client on the WiFi side. I'll see if I can find something that fits the bill that doesn't cost a fortune.
- TimSTLJun 10, 2024Guide
Just to round off this thread, I eventually went for a Mikrotik hAP AX2, which does the job. Nominally, it's a Wifi router, but it's one of the most capable and versatile I've come across. By that token however, getting it to do any one thing is pretty intricate and full of pitfalls, and took me a deal of experimentation.
