peterwfraser
Feb 27, 2019Follower
Can I use the ethernet ports when in AP mode?
Until recently I have been using the EX7000 as a range extender, with a couple of devices hard-wired to the ethernet ports. I now want to use it as an access point, and run an CAT6 cable from the rou...
Apr 06, 2019Guru - Experienced User
try this, disable ALL wifi at the main host router, Connect the EX with a LAN cable near the main host router. 6ft cat6 lan cable in between.
Are speeds the same or better while near the main host router?
peterwfraser wrote:
Until recently I have been using the EX7000 as a range extender, with a couple of devices hard-wired to the ethernet ports. I now want to use it as an access point, and run an CAT6 cable from the router downstairs to the EX7000 upstairs. Can I still use the EX7000's ethernet ports when it's configured as an access point? The manual seems to suggest I can't, but it's not clear.
Thanks
