RobAinscough
Jun 28, 2020Aspirant
Can I use two Nighthawk X4 WiFi Mesh extenders?
Are there any issues with running TWO Nighthawk X4 Wifi Mesh Extenders? If not, is the setup process the same for each extender? Cheers, Rob.
- Jun 28, 2020
There are no issues running multiple extenders.
Jul 06, 2020Guru - Experienced User
RobAinscough wrote:Hmmm ... looks like I spoke too soon. I ran a speedtest today because my internet seemed "slow" and I got 30 Mbps down and 41 Mbps up ... this is NOT good.
So I thought perhaps it was because of having two X4's, so I turned one off, still the same problem?
So I got my laptop and hooked it up directly into my ISP hardwire router's port via NIC and got 700Mbps down 43 Mbps up. So I know it's not an ISP issue, nor speed test location (San Jose CA).----hardwired is always going to give you faster speeds. Its the nature of how hardwired works versus wireless. And since the extenders run off the router, they're dependant on the router performing.
So I unplugged the 4X's and went back to using Powerline 2000 and was getting about 70-80Mbps.
I'm probably going to return these 4X's as they seemed to have issues unless someone has other recommendations? FYI, not related to have two 4X's since I get the same problem with just one 4X.
Cheers, Rob.
Did you try swapping the 2 extenders? Meaning you did power one down to try it but it you switch the 2 devices? If 1 device is having an issue, then its easy to start troubleshooting that device. but if both are having the same issue, then I look back at what they're connecting to. Which would be your isp's router. And testing a router hardwired isn't the same as testing it wireless. Plus the router's qos could be slowing the speed.
RobAinscough
Jul 06, 2020Aspirant
I tried switching them, with just one active, got the same results.
I understand hardwire will always be faster, I ran the test just to make sure it wasn't an ISP issue and I was getting good speed into my home.
Here is what I don't understand ... I used my Laptop's "wireless" (located about 5 ft away from the Nighthawk X4 living room unit) and ran the same speed test and got 497 Mbps down and 40 Mbps up ... the "client' light (on the Nighthawk X4) went ON (green) when my laptop connected for the speed test.
BUT, my PC when connected to a Linksys switch via hardwire and then the Linksys switch hardwire ethernet cable into the Nighthawk X4 and the same speed test on my PC resulted in 120 Mbps down and 40 Mbps up. Oddly it's faster today on the Nighthawk X4 but I still don't understand why the laptop connecting wireless to the Nighthawk X4 is 497 Mbps?
Puzzled, is there some sort of performance penalty for using the Ethernet port on the Nighthawk X4?
Cheers, Rob.
- CoaleyedJul 08, 2020Guide
You need to look at your wireless signal, not the internet speeds. Your throttle will come from that. If you are sitting at lets say 466.7Mbps, your internet isn't being degraded by the WiFi. I'd start channel surfing on the wireless signal to see if you get better results. Usually you will get Auto for 2.4 and 44 for 5.0.
