ChasCoxJr
Oct 28, 2015Aspirant
Can I use WN2000RPTV3 as wireless AP using Cat5 cable?
I have a WNDR4300v2 router and I am getting poor wifi download speeds to the basement of my home. I live in a small ranch style home with a basement and for some reason the signal degrades even with ...
- Oct 28, 2015
While many extenders can function as an Access Point with a wired connection back to the router, unfortunately, the WN2000RPT is not one of them. See the answer to question 1 on page 63 of the manual. It looks like the 2000 series extenders are all like this. The 3000 series and higher extenders can function as wired Access Points.
If you are willing to run Cat5 all the way to the extender, you may as well install an Ethernet switch and wire your basement devices to it.
You can also experiment with moving the extender closer to the router. It sounds like it's too close to the device. The ideal placement is mid-way, from a signal strength standpoint, between the router and devices.
TheEther
Oct 28, 2015Guru
