Michaelk7
Jul 23, 2021Tutor
Can not Connect NIghthawk X4 AC2200 to AC 1750 Cable Modem Router
Had it working great then an electric company cut the Suddenlink line for a day and I can not get it going again. Working to connect the range extender to the Cable Model listed below. I see it has...
Jul 23, 2021Guru - Experienced User
Does the modem work fine?
If so, have you tried factory resetting the extender and reinstalling it?
Michaelk7
Jul 23, 2021Tutor
Plemans,
Yes Sir, Modem works great. Have service on my iMac. Just working on getting the extender to work for ipads on opposite end of home. As instructed I am working with it next to my modem then will move it to it's location down the hall. I think the MAC number is giving me the problem.
How do you do a factory resetting? I will try that next.
Thank you for replying,
Michaeol
- Michaelk7Jul 23, 2021Tutor
P
Michaelk7 wrote:Plemans,
Michaeol
Plemans,Yes Sir, Modem works great. Have service on my iMac. Just working on getting the extender to work for ipads on opposite end of home. As instructed I am working with it next to my modem then will move it to it's location down the hall. I think the MAC number is giving me the problem.
MichaeolP
- plemansJul 23, 2021Guru - Experienced User
to reset, push and hold reset for 7-15 seconds while its powered on.
Then follow the install guide
Pardon the lapse in time as I have been taking care of the "Honney Do's" this afternoon. I appreciate your time and will tru that
If it were not for people such as yourself that give their time many people would be trouble including myself.
Again, thank you for your assistance.
Michael
